Jedi0719
Apr 11, 2020Follower
AC2200 Orbi Micro Router(RBR20) Not up to speed
So I spent alot of money investing in something new and sorry to say my Spectrum router seemed to work better as far as speed for wifi. I spent all day redoing all my my wifi devices spamrt pugs etc to get it all together. I have 300 mps- speed test on smart phones are good- gaming systems are 100-150mps- worst is smart TV that sits about orbi router is like 45 mps which Netfilix just spins and counts up. So wondering aside from reboot and resync and updating firmware (all of which have been done) what to do before I return it and suffer with old router? Also I need to see 2.4 version so I can sync Zmodo wireless security cams. Thanks for any help....
1 Reply
Built in router here? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopWhat is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
