Sarah10's avatar
Sarah10
AC2200 Orbi Micro Router(RBR20) not working after Plusnet outage
Plusnet went down for a few hours this afternoon and my AC2200 Orbi Micro Router (RBR20) has not recovered.  The Plusnet Hub 2 is working fine again and you can connect directly to it, but the Orbi i...
  • michaelkenward's avatar
    michaelkenward
    Jan 17, 2024
    Sarah10 wrote:
    So I clicked that, and it started going through the motions and then eventually said, "Existing Router or Gateway Detected Note: We detected an existing router or gateway on your network. You can still connect your Orbi router to your network and it will be set in router mode." AND THEN IT WORKED!
    The key bit there is "Existing Router or Gateway Detected".
    When routers do that, they can change the settings from the default, which means giving it an IP address that does not clash with the other router. It often goes for 10.0.0.1 rather than 192.168.1.1.
    p.s. Re the Plusnet Hub 2, I logged onto the admin site and in Advanced Settings>Broadband there is an enable/disable switch labelled 'bridging' with a warning, "Enabling Bridge mode means Routing, NAT, DHCP Server and Local DNS will be disabled. The Plusnet Hub will only act as a modem" - whether that is 'genuine' bridging, I do not know.
    It should be right, but that message suggests that the Plusnet thing was not fully bridged and in modem only mode.
    Maybe it was down to the order of rebooting the network.
    Now that you have got things going as required, it might be a good idea to create backup of your Orbi settings. Then you can recover the next time the sky falls in.
    How do I back up the configuration settings on my Orbi WiFi System? - NETGEAR Support
    Nice to know that Netgear's various apps and wizards have their place and can get things right.
