Joelovinlife
May 03, 2020Aspirant
AC2200 Orbi Router(Dos Attacks - Loss of Service)
So I'm having the popular issue of DOS attacks. I've done some research and see most Netgear Routers report these in their logs. However, I lose internet connection randomly through out the day and al...
Mstrbig
Aug 09, 2020Master
OrbiPhilip wrote:
How would an LOS create the illusion of a DDOS?
It would be the other way arround overwhelming DDOS attacks causing LOS.
OrbiPhilip
Aug 10, 2020Luminary
Mstrbig wrote:It would be the other way arround overwhelming DDOS attacks causing LOS.
That would be my expectation as well. I was referring to Schumaku's comment, "Most occurrences are false positives, caused by _real_ connection loss on the WAN/Internet side..."
Mstrbig wrote:
Have you tried checking "Disable Port Scan and Dos Protection", under advanced, setup, WAN setup?
my page is set this way and I get no DDOS reports in log or LOS:
So actual DDOS attacks don't take it down, but the router's attempts to prevent them do? Interesting.
