John1981
Aug 28, 2018Aspirant
AC2200 phone line
Recently purchased the AC2200-RBK40. I have a phone line thru my ISP and want to use the Orbi instead of the modem that came with ISP. Did i waste my money buying the Obri? Or is there a way to connect my phone line to this system?
Please post this here:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
This form is for the cable modem Orbi.
Phone lines thru ISP required speciallized phone modems that come from the ISP.
Good Luck.
- John1981Aspirant
Im not savy in these ways. Could you break that down dummy style for me? At least the set up you have. Could i still keep the Orbi and hook it up to another non wifi modem thru the Ethernet ports? Or do i just need to take it back?
- Blanca_ONETGEAR Employee Retired
Hi John1981,
Welcome to NETGEAR Community!
Please describe your current setup : ISP and model number of the modem.
Blanca
Community Team
- John1981Aspirant
Xfinity and AC2200
Hi John1981,
This kit RBK40 (AC2200) comes with an Orbi WiFi Router and Satellite. The router should be connected to a cable modem. You may want to check this link https://kb.netgear.com/31017/How-do-I-set-up-my-Orbi-router-and-satellite as reference of how to set it up.
Blanca
Community Team
I believe the OP has internet phone service with his ISP in which I presume the ISP requires the user of there modem. So I presume in his case, if he needs the ISP modem, he should get in to a non cable modem Orbi system like the RBK50 or 40 series, someting with out the built in cable modem.
- vkdeltaNETGEAR Employee Retired
If you have a phone service with ISP and need Orbi system, it is better to buy following combination of units.
CM500V (For Modem and Voice)
RBK50 (for Router and WIFI)
CBK40 DOES NOT support voice.
you can ask xfinity to split voice into ISP modem and keep data on CBK40 but then you will still be paying rental fees for ISP modem.
in our online postin on amazon, it specifically states that "
- **Not compatible with bundled voice services from Cable Internet Service Providers."
Thank you Sir.
