ehsiii
Oct 12, 2019Aspirant
AC2200 (RBK44) 4 pack system
I am getting the AC2200 (RBK44) 4 pack system . Are the satallites that come with 4 pack sytem the RBS40 wirless range exstender? If the RBS40 is different . Would this be good for a barn beside ...
- Oct 12, 2019
its pretty much ideal if you have them wired with an ethernet backhaul. If you're putting one of the rbs20's in the apartmet side of the barn (low dust/moisture) you should be fine.
In terms of the cm1000, I'd recommend it. I've got one and it works great. It also allows you the ability to upgrade to faster speeds without having to upgrade the modem in the future.
