ehsiii
Oct 12, 2019Aspirant
AC2200 (RBK44) 4 pack system
I am getting the AC2200 (RBK44) 4 pack system . Are the satallites that come with 4 pack sytem the RBS40 wirless range exstender? If the RBS40 is different . Would this be good for a barn beside ...
- Oct 12, 2019
its pretty much ideal if you have them wired with an ethernet backhaul. If you're putting one of the rbs20's in the apartmet side of the barn (low dust/moisture) you should be fine.
In terms of the cm1000, I'd recommend it. I've got one and it works great. It also allows you the ability to upgrade to faster speeds without having to upgrade the modem in the future.
ehsiii
The Barn is more storage with a apartment up top made of wood would be about 150 feet from the main router . It is 10 feet of the main house about 1500sf I am planning on using the Ethernet Backhaul to hook them all up .
The cable modem my xfinity package is 100mps per sec . Its better than that but thats what they say.. I have been looking at the CM1000 for the cable modem ..what do you think about that ? thanks for the help guys
Oct 12, 2019Guru - Experienced User
