yodar444
Nov 07, 2018Tutor
ac2200 weak 30 ft away
i have an ORBI ac2200. i am trying to connect to it from a win8.1 computer ~ 30 ft away. i have tried 3 different wifi adapters, but only 1 even sees the orbi and it connects with a VERY slow speed. ...
Nov 07, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What adapters have you tried?
Can you connect a ethernet cable from this PC to the Router?
Have you tried moving the satellite closer to the PC and then connect a ethernet cable to the satellite from the PC?
- yodar444Nov 07, 2018Tutor
what do you mean by FW?
what does FW stand for ?
- FURRYe38Nov 07, 2018Guru - Experienced User
FW=Firmware
i still don't understand what FW you mean. the win 8.1 computer is up to date. the NG ac2200 is new.
the modem is a arris surfboard sb6141, connected to a NG ac2200
home is 2000 sq ft
there is no satellite.
no, the pc is in another room.
no. there is no practical way to do that.
- FURRYe38Nov 08, 2018Guru - Experienced User
You may need to get a better wifi adapter.
Can try Netgear Adapter: https://www.netgear.com/home/products/networking/wifi-adapters/
or a D-Link DWA-192
home is 2000 sq ft
