yodar444
Nov 07, 2018Tutor
ac2200 weak 30 ft away
i have an ORBI ac2200. i am trying to connect to it from a win8.1 computer ~ 30 ft away. i have tried 3 different wifi adapters, but only 1 even sees the orbi and it connects with a VERY slow speed. ...
Nov 07, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What adapters have you tried?
Can you connect a ethernet cable from this PC to the Router?
Have you tried moving the satellite closer to the PC and then connect a ethernet cable to the satellite from the PC?
