yodar444
Nov 07, 2018Tutor
ac2200 weak 30 ft away
i have an ORBI ac2200. i am trying to connect to it from a win8.1 computer ~ 30 ft away. i have tried 3 different wifi adapters, but only 1 even sees the orbi and it connects with a VERY slow speed. ...
ekhalil
Nov 08, 2018Master
cell phone wifi analyzer shows good signal there [50-70%]
what should i use to connect to the orbi?
I had similar issue. The problem was not in the PC or in the wifi coverage.
How many Satellites do you have?
Can you please switch off the Satellites and see if your computer will connect to Orbi if only the Router is on?
