ejsegrav
Jul 06, 2023Aspirant
AC3000 Auto Negotiate WAN Disable
Is there a way to disable or force a speed negotiation from the AC3000 router? My ISP can force a speed on their end but I can't find anything on the router admin pages that mention WAN speed. I am...
Jul 06, 2023Guru - Experienced User
No, WAN is Auto detect
What model Orbi do you have? RBK##?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
ejsegrav
Model - RBR50V2
Firmware V2.7.4.24
Cat 6 cable being used
Router has been in use over 1 year
I am not sure of the particulars of the ISP...I will ask them.
- FURRYe38Jul 06, 2023Guru - Experienced User
After getting particulars of ISP modem/ONT, might review new FW thats available as well.
