mrfish1228
Jan 17, 2023Aspirant
AC3000 Gigabit Speed Upgrade Failure
I just upgraded amy internet service to gigabit speed. When I plug directly into the wall, the speed is over 900, but when I go through my Orbi AC300, it maxs out at 300. Is there a setting that need...
- Jan 20, 2023
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Ethernet speeds with a wired PC connected at the RBR should see near 900Mpbs with Ooklas installable speed test app.
Wireless speeds with a wireless PC could be anywhere from 200-500Mpbs depending on the devices design and support. You'll never see anything near 900Mpbs on 5Ghz AX on this model Orbi.
mrfish1228 wrote:
I just upgraded amy internet service to gigabit speed. When I plug directly into the wall, the speed is over 900, but when I go through my Orbi AC300, it maxs out at 300. Is there a setting that needs to be changed or something different that needs to be done to access the gigabit speed through my Orbi?
Jan 17, 2023Guru - Experienced User
Did you try factory resetting the orbi?
Always worth a chance after changing services/speeds
After the reset, make sure to leave qos, access control, traffic monitoring, and parental controls all disabled during the install.
Then test it.
