mrfish1228
Jan 17, 2023Aspirant
AC3000 Gigabit Speed Upgrade Failure
I just upgraded amy internet service to gigabit speed. When I plug directly into the wall, the speed is over 900, but when I go through my Orbi AC300, it maxs out at 300. Is there a setting that need...
- Jan 20, 2023
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Ethernet speeds with a wired PC connected at the RBR should see near 900Mpbs with Ooklas installable speed test app.
Wireless speeds with a wireless PC could be anywhere from 200-500Mpbs depending on the devices design and support. You'll never see anything near 900Mpbs on 5Ghz AX on this model Orbi.
mrfish1228 wrote:
I just upgraded amy internet service to gigabit speed. When I plug directly into the wall, the speed is over 900, but when I go through my Orbi AC300, it maxs out at 300. Is there a setting that needs to be changed or something different that needs to be done to access the gigabit speed through my Orbi?
mrfish1228
Thanks for the quick reply. The model number is RBR50v2 and I'm measuring the speed via speedtest.net (ookla). When I use my Orbi app on my iPhone, the download speed is 939 Mbps and the upload speed is 903 Mbps. When I do the speed test on my laptop, download speed is 173.79 and upload is 120.98. Why the huge discrepancy? What can I do to fix it?
CrimpOn
Jan 17, 2023Guru - Experienced User
The Orbi 'app' does not actually "do anything." It sends a message to the router, which performs a Speedtest licensed from Ookla and sends the results back to the app to be displayed.
Results on a laptop will depend on how it is connected to the router.
- A relatively modern laptop on an Ethernet connection might not the ISP full speed, but it should report much greater speed than that. My 8 year old desktop that is wired to the same router (RBR50V1) gets the same speed as the router (350Mbps from Spectrum) I pay for 200Mbps, so I'm happy.
- A laptop connected over WiFi will depend on (a) the capability of the laptop WiFi adapter and (b) the distance from the router.
- mrfish1228Jan 25, 2023Aspirant
Thanks for your feedback - I've gotten it corrected!
- FURRYe38Jan 25, 2023Guru - Experienced User
So what did you do to correct it?
Added Cat 6 cable and repositioned the Orbi router.
