zsann
Jun 07, 2017Aspirant
AC3000 Orbi RBR50 General questions before buying
I'm looking to purchase the 3-Pack AC3000 system from Costco, I have a 2500 sq-foot Split-ranch (US). I really like the capabilites of the Orbi, and I think it'll work very well. I know I don't n...
- Jun 08, 2017
zsann wrote:1) the dedicated 3rd band used for connection between the router and satellite, does that apply if you have more than one satellite? As in, w/2 satellites, would one be connected via the 3rd band and another by the standard bands, or would both be connected by the 3rd band, OR would both be connected via a standard (2.5/5GHz) band?
2) I see a lot of posts abt issues with Apple devices and connections: do they persist still, or is it fixed with latest firmware? Has anybody still had a lot of problems? I have many apple devices, though not all are Apple.
3) I know that Orbi uses a star topology: if my router has to be on one side of the house(say left), can 2 satellites be placed on the right hand sides, but different lvls, for example, or does a strict left-router-right configuration work best?
Thanks for any help you guys can give me!
1) The backhaul is shared among the satellites.
2) Some users, including me, have never had any issues. There are some users who continue to have issues. Those with issues seem to be a small percentage of users, but you see them represented here disproptionately. If you buy Orbi, I'd recommend you wring it out thoroughly and be prepared to return it if you are one of the few who have issues.
3) You could place the router on one side and the two sats on the other side, but it might not work well. Better to put the router in the middle and the sats on the two ends. This minimizes the distance between the router and sats.
Orbi has been working well for me with one router and one sat in a 3-level 3000 SF house.
st_shaw
Jun 08, 2017Master
