jleecloak1
Jul 02, 2017Apprentice
AC3000 Orbi RBR50 General questions before buying
I had my original Orbi replaced after several months of issues. I contacted support for a replacement RMA and I have to say it's been running smoothly so far. I have still had some issues with Androi...
ew2x4
Jul 05, 2017Aspirant
Unfortunately, I bought mine off an ebay store that wasn't on the authorized reseller list. So instead of an RMA, I'm stuck with a brand new, yet faulty device.
jleecloak1
Jul 05, 2017Apprentice
Have you tried the latest beta firmware? I hope that if can fix your problems.
My wireless devices kept disconnecting very frequently last night but I am hoping it was due to the bad weather in the surrounding areas. I couldn't even play any multiplayer games because I kept getting disconnected. I will test it again tonight to see if it was not my Orbi.
- ew2x4Jul 05, 2017Aspirant
How do i get on the beta firmware?
- jleecloak1Jul 05, 2017Apprentice
DarrenM may be able to help you get the beta firmware or you can email support. They send it pretty quickly. My experience has been good with getting beta firmware.
