jleecloak1
Jul 02, 2017Apprentice
AC3000 Orbi RBR50 General questions before buying
I had my original Orbi replaced after several months of issues. I contacted support for a replacement RMA and I have to say it's been running smoothly so far. I have still had some issues with Androi...
DarrenM
Jul 05, 2017Sr. NETGEAR Moderator
What issues are you having with the unit?
DarrenM
ew2x4
Jul 05, 2017Aspirant
Inconsistant speeds and disconnects.
On one device, I'd be hitting my max 200 mbps, on every other it would be under 20. It would be inconsistant which device would be fast. Range would decrease to under 10 feet. 2.4 Ghz freq drops out.
This happens about one day a week then returns to normal. After 3 hours on the phone, they decided to RMA it.
