marin21
Apr 17, 2019Follower
AC3000 Problem with Wifi connection every minute
Firmware V2.3.1.44
Replaced my old router yesterday evening with the Orbi (with one satellite) and it worked well for a while.
This morning the wify disconnects every minurte or so on both la...
Apr 17, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
