marin21
Apr 17, 2019Follower
AC3000 Problem with Wifi connection every minute
Firmware V2.3.1.44
Replaced my old router yesterday evening with the Orbi (with one satellite) and it worked well for a while.
This morning the wify disconnects every minurte or so on both la...
Apr 18, 2019Guru - Experienced User
Any progress on this?
marin21 wrote:
Firmware V2.3.1.44
This morning the wify disconnects every minurte or so on both laptops and iphones.
- Using an eithernet cable works fine.
- I have tried using different channels on both 2.4 and 5Ghz network.
- Tried disable 20/40 MHz Coexistence
- Tried disable Daisy-Chain Topology.
- Tried Enable Implicit BEAMFORMING
- Tried different Preamble Mode
The only difference from yesterday I can think of is if the router have upgraded its firmware in the background.
If I switch back to my old router it works ok as usual, (slow and poor range as expected).
Frustration is running high and I have not got a black belt in networks and wifi and hoping for a noob problem/solution... ;)
Regards
Peter
