scottr0001's avatar
scottr0001
Follower
Feb 14, 2018
AC3000 RBK50 - iPad Pro WiFi connection issues
Base and satellite is on firmware release 2.1.2.18.   iPad Pro will connect/disconnect without issue. Unfortunately, it won’t properly renew the DHCP lease daily. I will come back the next day and ...
  • FURRYe38's avatar
    Feb 24, 2018
    I disabled the following on the Orbi router:
    Implicit BEAMFORMING - Boosts WiFi speed, reliablity, & range for all mobile devices
    MU-MIMO
    IPv6.
