Rivernomad
Nov 09, 2018Aspirant
AC3000 RBK50 - iPad Pro WiFi connection issues
Good morning,
i have issues with the connectivity between my ORBI RBK53 (downloaded and installed latest firmware v2.2.1.210)
my Ipad Pro shows to be connected to wifi over the ORBI system, but s...
Rivernomad
Nov 11, 2018Aspirant
Thanks for the reply, but the router is absolutely the ORBI router. When I called the helpdesk, they mentioned that this was a common problem with NEW Ipad Pro models as well as Iphones. I find it strange however, that neither Netgear, not Apple has sofar come up with a patch.
Nov 11, 2018Guru - Experienced User
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-p/1601598/highlight/true#M35230
https://community.netgear.com/t5/Orbi/Have-to-keep-rebooting-my-RBR50/m-p/1658603/highlight/false#M44420
Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
