Hobbs13
Dec 02, 2018Aspirant
AC3000 (RBK50) - Wifi Calling Not Working
Hardware: AC3000 (RBK50)
ISP: Verizon FIOS 1GB
Phone: iPhone XR
There is no other modem or router. Just the FIOS line plugged directly into the Orbi. I have AT&T cell service and its really poo...
Hobbs13
- ekhalilDec 02, 2018MasterThe only QoS settings is WMM (Wifi Multi Media) and you can find it under ADVANCED >> Advanced Settings >> Wireless. There you can enable or disable WMM for 2.4 GHz and 5 GHz bands. You should have it enabled.
- Hobbs13Dec 03, 2018Aspirant
ekhalil - Thanks for the reply. However those settings are already enabled.
Any other suggestions? I am struggling as I have full WiFi signal, but many times 1 bar of AT&T service.
Calls are dropping frequently inside the house.
- ekhalilDec 03, 2018Master
Something else to consider is to if you have packet drops in Orbi. I noticed a case when this can happen if you have loops in the network.
What wired devices do you have connected to Orbi?
