Hobbs13
Dec 02, 2018Aspirant
AC3000 (RBK50) - Wifi Calling Not Working
Hardware: AC3000 (RBK50)
ISP: Verizon FIOS 1GB
Phone: iPhone XR
There is no other modem or router. Just the FIOS line plugged directly into the Orbi. I have AT&T cell service and its really poo...
Dec 03, 2018Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
Phone: iPhone XR
There is no other modem or router. Just the FIOS line plugged directly into the Orbi. I have AT&T cell service and its really poor inside my house. No more than 1 bar. Wifi Coverage with the Orbi is great. Full bars in every room. I have WiFi calling enabled on the iPhone... however, I consistently drop calls when in my house.
In the iPhone status bar, I see AT&T WiFi next to the WiFi signal icon. So the phone should be using WiFi. However even with full WiFi signal. I am dropping calls. Something has to be configured wrong.
Any configuration thoughts on the router side? I see nothing to enable. QOS section only has a "speed test" and no settings to configure. What am I missing here?
#Frustrated
