rfitz73's avatar
rfitz73
Follower
Aug 08, 2017
AC3000 RBK50
i have the Orbi AC 3000 RBK53. I also have AT&T Uverse with worless cable boxes. the issue i have is either the wireless cable box functions properly or the Orbi signalworks properly but they do not function well at the same time. Its one or the other. Is there an issue with there signals competeing with each other?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello rfitz73
    yes you should bridge the cable modem to be a modem only.
    DarrenM
