ThanhHien
Sep 26, 2017Aspirant
AC3000 router and satellite - no internet access or weeak signal
Hello, I purchased the AC3000 with satellite on 9/14. The installation and set up were easy. However, the system does not perform properly. It might work for several hours or days then there there ...
aaz
Sep 26, 2017Virtuoso
It's usually not a goot idea to have two routers inline, you may want to try to switch your comcast router to bridged mode and let the Orbi do the routing. With the way you have it connected I doubt you can easily find where the trouble is. You may also want to make sure your firmware is up to date -- ver 2.0... available to install manually currently.
- ThanhHienSep 30, 2017Aspirant
Should both GATEWAY MODE and Primary Nework only Mode chagne to bridged? Thak you for your help.
- aazOct 01, 2017Virtuoso
ThanhHien wrote:Should both GATEWAY MODE and Primary Nework only Mode chagne to bridged? Thak you for your help.
I don't have experience with Comcast, but from online reading it appears that Gateway mode is what matters - and when you set that to bridged then Primary network mode becomes inactive. If you want to undo that change you may need to reset the cable modem or call the ISP.
