ThanhHien
Sep 26, 2017Aspirant
AC3000 router and satellite - no internet access or weeak signal
Hello, I purchased the AC3000 with satellite on 9/14. The installation and set up were easy. However, the system does not perform properly. It might work for several hours or days then there there ...
ThanhHien
Sep 30, 2017Aspirant
Should both GATEWAY MODE and Primary Nework only Mode chagne to bridged? Thak you for your help.
aaz
Oct 01, 2017Virtuoso
ThanhHien wrote:Should both GATEWAY MODE and Primary Nework only Mode chagne to bridged? Thak you for your help.
I don't have experience with Comcast, but from online reading it appears that Gateway mode is what matters - and when you set that to bridged then Primary network mode becomes inactive. If you want to undo that change you may need to reset the cable modem or call the ISP.
