RickPC
Apr 16, 2020Aspirant
AC3000 vs. AC2200: Maximum Distance Between Satellites in Daisy Chain Configuration
I am trying to determine whether there is any a material difference between the AC3000 and AC2200 mesh network, if I need to maximize distance between two satellites in a daisy chain configuration.
RickPC
I can set the first satellite wtihn 30 ft of router. Howevere, I want to run about 60 feet or a bit more rom that satellite to the next. it would be across an open space through two windows..home to garage office.
Apr 16, 2020Guru - Experienced User
RBS should not be closer than 30 feet. Any closer and the wifi over lap between the RBR and RBS becomes bad. Causes problems.
- Retired_MemberApr 16, 2020
This is not 100% true.
The user should be advised to try what works for their specific coverage area. It's NOT a one size (distance) fits all.
Pay attention to the ring color on the Orbi and the Sats, that will be your best gauge for your situation.
