drwalther's avatar
drwalther
AC3000/RBR50 WiFi Failure
I am grateful for your assistance, since the novice stuff accessible at my level (updating firmware, rebooting, hard restarts) have failed.     Device specifics: firmware version V2.7.3.22 (when t...
  • drwalther's avatar
    drwalther
    Feb 13, 2022
    CrimpOn! truly "sensei"!  Thank you!
    In iOS, go to Settings-->Wi-Fi, and there's a blue "i" in a circle, to the right of the Wi-Fi network to which one is connected. Tap the circled i (yes, it means "info"...) scroll down to the phrase "Private Wi-Fi Address." The default setting is "on." Toggle it to the left so the green is replaced by grey.  It appears rebooting device, but most especially rebooting the Orbi, is useful, if not necessary. Note: Apple will place the phrase "Privacy Warning" beneath your chosen Wi-Fi network name after private address is off.
    Private Address is a new security feature by which Apple has deemed to increase our privacy (KUDOS to them for this, and for caring at all about privacy!).  Unfortunately, it appears that, HAT TIP CrimpOn!, the Orbi software is frustrated by the daily generation of a spoof MAC (Medial Access Control...not any other MAC you might be thinking) address (what makes the privacy in the "private address" feature.)  I don't see a huge deal just turning it off, since it's our home network, and is as secure as the protocols permit it to be. It is early, but this seems to have restored our internet access via the Orbi Wi-Fi signal.
    I suspect many are affected by this.  I hope this helps.
    Please Netgear, in the next firmware update, please code to embrace this feature!
    Thank you CrimpOn! Superuser indeed! (maybe one day I'll move up to inserting cool pics with highlights, circles, arrows and the like, rather than indulging in excessive verbosity!
