londonaz2003
Oct 20, 2021Aspirant
Access a Security Camera DVR from outside local network
I have an Orbi router with one satelitte. This was installed to replace an ISP provided router that 'failed'. The ISP also replaced the Modem. The current configuration is an ISP provided Evolution M...
londonaz2003
Oct 22, 2021Aspirant
Well I can now access my PC on the Orbi network without intervention locally. Google Chrome Remote Access is very simple to use.
I spoke with Netgear Level 2 tech who believes the issue is with the NVR. I’m not totally convinced. He did ask me to change the NAT parameter in the Orbi from Secure to Open. Did not make a difference. He assured me it did not expose my network. I will be changing it back. Netgear’s view is that if the camera feed can be accessed from a cell phone connected to the Orbi WiFi then Orbi is proven to not be the problem and accessing the NVR from outside the network cannot be impacted by the Orbi. Doesn’t sound right to me.
The NVR is a NVR-SB4ME-4P
My next strp is to try to access the DVR from the local PC and check all of the settings. I believe there is an app called CMS that should be able to do that.
CrimpOn
Oct 22, 2021Guru - Experienced User
Doesn't sound correct to me, either. The issue is remote access using Port Forwarding. I am confident that Port Forwarding "works". I have a Pi-hole DNS filter that runs a web server on port 80 for administration. When I forward port 80 to the Pi-hole, I can connect to it from the internet. "no problem". (I do not leave the port forwarded because the instant a port is forwarded, bots begin a constant stream of connection attempts and the password on this web server is not long and complicated.)
From the NVR setup, those three ports have different uses. Up to 10 simultaneous clients on the web interface (currently 8080). 554 is for RTSP video streaming. 6036 is for the management interface.
