_DamN_
Jan 28, 2021Aspirant
Access Control - Orbi
Hardware Version RBR50
Firmware Version V2.7.2.102
GUI Language Version V1.0.0.375 After recent upgrade to above mentioned firmware I lost "access control" from web GUI. From what I understood so...
- Feb 18, 2021
So just a quick update: we had a power outage recently which forced my Orbi to the power cycle. Looks like Orbi realized that his owner is a bit pissed due to that Access Control feature not being available and "it fixed itself". This morning, just randomly checking the status of the devices on the network I saw "Access Control* being available again. I do not like this behavior but seems like the only thing which was required from me to do was a power cycle procedure instead of just rebooting the device. Anyway, closing this thread and looking forward to write another questions as my Orbi announced new firmware being available for me.
Thanks to all who responded !
_DamN_
Feb 18, 2021Aspirant
mpjayne
Jul 09, 2022Aspirant
This was helpful and the end result is that I will attempt to Factory Reset my Orbi. MY ISSUE is that my kid keeps changing his Computer IP so it allows him access to his satellite. I want and NEED the ability to say "ok, go ahead and access" or "NO ACCESS FOR YOU right now!!". Can't do that as of now. Hopefully I will upon reset and setup.
- CrimpOnJul 09, 2022Guru - Experienced User
A lot has changed in the past 15 months. It may be more productive to begin a new discussion by posting in the correct forum for your specific model of Orbi:
Original Orbi AC products (50, 40, 20): https://community.netgear.com/t5/Orbi/bd-p/Orbi
Newer Orbi AX products (750, 850, 960 etc): https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/bd-p/en-home-orbi-ax
It will help if you mention
- the specific Orbi model
- whether you administer the Orbi using the web interface or the Orbi 'app'
- if you have subscribed to one of the Parental Control features
Good Luck
