mc64
Oct 22, 2018Tutor
Access Control Bug in Orbi V2.2.1.210
Until the last firmware upgrade, access control worked fine. I had "prevent new devices from connecting" enabled as well. When I recently installed a new device and went to allow it to connect as I'v...
marquisT
Feb 01, 2019Aspirant
I've finally tracked down the problem (random Access Blocked settings): it started when I added a new PC to the network via an ethernet connection. Once I disconnected, the problem went away. I put that same PC back on the network with a WiFi dongle, and then later with a USB-Ethernet adapter, and did not have the problem.
Is that a problem with this particular Ethernet port? Or something related to the current Orbi firmware? I have no idea. But thought I'd share that to see if anyone else hit this problem due to a "bad" ethernet port.
- FURRYe38Feb 01, 2019Guru - Experienced User
Ethernet port on the Orbi or on the PC?
What is the Mfr and model# of the ethernet adapter on the PC?
- mc64Feb 01, 2019Tutor
Read the entire thread or search in the communities. This is a firmware bug that Netgear has yet to address.
- marquisTFeb 01, 2019AspirantI assume the PC, not the Orbi, since that is the new component in the mix. According to the Device Manager, it an Intel Ethernet Connection I217-LM. There are about 20 properties that can be set (Device Manager | Network adapters | Intel Ethernet Connection I217-LM| Properties|Advanced). Any thoughts about any of those parameters that might avoid this supposed conflict? Thanks.
You might contact Intel support and see if there is any specific settings in the adapters properties that could elliviate this issue.
You might file a support ticked as well with NG and have someone review it:
https://www.netgear.com/mynetgear/registration/login.aspx
I would also ask NG for a beta to see if it may have been fixed:
