mc64
Oct 22, 2018Tutor
Access Control Bug in Orbi V2.2.1.210
Until the last firmware upgrade, access control worked fine. I had "prevent new devices from connecting" enabled as well. When I recently installed a new device and went to allow it to connect as I'v...
marquisT
Feb 01, 2019Aspirant
I assume the PC, not the Orbi, since that is the new component in the mix.
According to the Device Manager, it an Intel Ethernet Connection I217-LM.
There are about 20 properties that can be set (Device Manager | Network adapters | Intel Ethernet Connection I217-LM| Properties|Advanced).
Any thoughts about any of those parameters that might avoid this supposed conflict?
Thanks.
Feb 01, 2019Guru - Experienced User
You might contact Intel support and see if there is any specific settings in the adapters properties that could elliviate this issue.
You might file a support ticked as well with NG and have someone review it:
https://www.netgear.com/mynetgear/registration/login.aspx
I would also ask NG for a beta to see if it may have been fixed:
marquisT wrote:
I assume the PC, not the Orbi, since that is the new component in the mix. According to the Device Manager, it an Intel Ethernet Connection I217-LM. There are about 20 properties that can be set (Device Manager | Network adapters | Intel Ethernet Connection I217-LM| Properties|Advanced). Any thoughts about any of those parameters that might avoid this supposed conflict? Thanks.
