jbrown316
Nov 04, 2020Apprentice
Access control issue/bug with Orbi 2.7.1.60
Since I upgraded to the latest firmware, the Access Control feature in Advanced...Security in the UI doesn't work properly. When I turn access to certain devices off, it is also turning off access t...
Nov 13, 2020Guru - Experienced User
When connecting the RBS, it's recommended to first sync the RBS, one at a time to the RBR wirelessly. I would do this near or in same room as RBR. Setup a IP address reservation for the 1st RBS ON the RBR or host router. Do same for 2nd RBS. Once both RBS are wirelessly connected and IP reserved, ethernet connect 1 RBS at a time to the RBR. Once both are ethernet connected and show WIRED for the connection status ON the RBR, turn the RBS OFF and then place at there remote locations.
And Daisy Chain should be disabled if your RBS are in Start or Spoke formation around the RBR.
