MikeG63
Sep 14, 2023Apprentice
Access Control Lists for Orbi RBR50
In recent days I have experienced issues when existing devices have tried to reconnect to my router. It turns out that the problem was my ACL list had reached a maximum allowable of 128 devices in t...
CrimpOn
Sep 16, 2023Guru - Experienced User
MikeG63 wrote:
As I only have currently 32 devices connected my question is can I clear out my ACL and strat over, and if I did do this would there be any detrimental effect on my existing devices or would a simple reboot re-populate the allowed list as I have ticked allow new devices to connect to the router.nks
Mike
The router keeps a list of every device that has been "Allowed" and every device that has been "Blocked" so that it can recognize a device when it attempts to connect again. Clearing these two tables in the Access Control menu page simply means that any device that is not currently connected will be treated as "New". With the setting to allow new devices, that means the table will grow gradually over time. Rebooting does not change the contents of the table. So, if the table is cleared out, then it will remain cleared out when the system reboots. If some new devices are added to the table, then they will remain in the table after a reboot.
MikeG63
Sep 16, 2023Apprentice
I'm guessing then from what you say that if I clear my allowed and blocked ACL lists, and selecting allow new devices to connect my existing devices, after a reboot, will then simply re-connect which will populate the allowed ACL list and I can then monitor the ACL and block any unrecognised devices in the unlikely event that scenario occurs. I am tempted to just turn the ACL function off as it's super unlikely that someone will try to hack my password and gain control.
