AkoreJepade
Nov 07, 2019Tutor
Access Control on RBR50 with V2.5.0.38 firmware
Since that last firmware upgrade the systems Access Control is all a mess. It even managed to Block one of my Satellites so I ended up having to turn off Access Control. Also I fear that if I reboot...
AkoreJepade
Nov 07, 2019Tutor
Thanks for the fast reply, No I have not tried a factory reset of the router yet... I did see that mentioned on a search but wanted to post here before I did that to see if that was the only solution.
Nov 07, 2019Guru - Experienced User
Seen odd issues with this FW update. Resets seems to help fix most of them.
