qtschlepper
Oct 15, 2018Star
Access Control randomly blocking approved devices on V2.2.1.210
RBR50
After upgrading to the V2.2.1.210 router firmware, i'm finding that devices that have approved MacID addresses and have been previosly on the network for months are suddenly being blocked in...
Oct 15, 2018Guru - Experienced User
How was the FW updated, via auto update or did you manually install the FW files and continue or a reset back to factory settings then setup from scratch?
Has a full power OFF for 1 minute then back ON of the Orbi system been performed after the FW update?
qtschlepper
Oct 15, 2018Star
Did a pull update from the dashboard, and then simply let it reboot. I can go power it down for an additonal step.
