qtschlepper
Oct 15, 2018Star
Access Control randomly blocking approved devices on V2.2.1.210
RBR50
After upgrading to the V2.2.1.210 router firmware, i'm finding that devices that have approved MacID addresses and have been previosly on the network for months are suddenly being blocked in...
qtschlepper
Oct 15, 2018Star
qtschlepper wrote:
Did a pull update from the dashboard, and then simply let it reboot. I can go power it down for an additonal step.
Did that - Looks like I'm getting the false blocking that others are reporting.
Christian_R
Oct 16, 2018NETGEAR Employee Retired
Hello qtschlepper - Thank you for reaching out. Please send me a message with your contact info and I will have support get in contact with you.
~Christian
- qtschlepperOct 16, 2018Star
Just to put a fine point on it, I went to confirm if it was just the web page mis-reporting bug or if it was REALLY blocking. Turns out that the iMac-wireless and my wireless Tivo were both marked blcoked when I returned to the admin console on Chrome. (not using mobile or iOS) I confirmed that they were both indeed really blocked, and unblocked them with the edit function, as the unblock checkbox was ineffective. Both were immediately restored. I have to say that it's truly annoying having to check back in and turn on my approved devices without a heads up that they were turned off. Now if there was some superduper cybersecurity Ai that thought that these devices were compromised and out of a abundance of caution it was killing the command and control I would be thrilled. But i'm sure thats not the case.
- FURRYe38Oct 16, 2018Guru - Experienced User
- mc64Oct 22, 2018Tutor
I'm having the same problems. I've had to turn off access control, which is VERY annoying.
