qtschlepper
Oct 15, 2018Star
Access Control randomly blocking approved devices on V2.2.1.210
RBR50
After upgrading to the V2.2.1.210 router firmware, i'm finding that devices that have approved MacID addresses and have been previosly on the network for months are suddenly being blocked in...
Oct 23, 2018Guru - Experienced User
It's meant as a work around solution for now until NG gets the bug fixed.
mc64 wrote:
"Manually install firmware and perform factory reset?" That's not really a working solution. I've *been* a network engineer and that's a lame response for terrible QA.
qtschlepper
Oct 23, 2018Star
As much as I agree with you, this may in fact be the first time in history this actually worked. As of today the problem still hasn't reappeard. But i'm checking twice a day, as i'm skeptical as well.
- FURRYe38Oct 23, 2018Guru - Experienced User
Keep us posted. If NG knows about it, hopefully it should appear in next FW update.
- mc64Oct 23, 2018Tutor
That's not a reasonable workaround IMO. I've worked for software product companies, IMO, QA/relase process needs serious improvement. The bug fix should be a priority and I don't see any indication that it is. As a 22-year veteran in this industry, I'm appalled.
Well untill next FW update, users can use the work around. not the first bug nor probably the last.
Good Luck.
Or users can go elsewhere, i.e. another vendor. It's probably what I'll do.
Good Luck then. Enjoy. :smileywink:
- FURRYe38Jan 15, 2019Guru - Experienced User
Was wondering how yours is working for you?
