qtschlepper
Oct 15, 2018Star
Access Control randomly blocking approved devices on V2.2.1.210
RBR50
After upgrading to the V2.2.1.210 router firmware, i'm finding that devices that have approved MacID addresses and have been previosly on the network for months are suddenly being blocked in...
james7777
Jan 15, 2019Tutor
I may need to reconnect my Orbi system to try this on mine. I have it in the box ready to go back to Costco because of this issue currently.
Jan 15, 2019Guru - Experienced User
Let us know if this works for you or not.
How many satellites do you have? 1 or more?
Seen other posting about seeing reverse behavior with Daisy Chain and it being disabled when checked and enabled when unchecked. Hard to verify this. NG is aware of Daisy Chain issues.
Having just 1 satellite, Daisy Chain should be disabled.
- mc64Jan 15, 2019Tutor
I only have a single satellite.
- FURRYe38Jan 15, 2019Guru - Experienced User
Let us know if this helps you and how you have the check box set.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
