qtschlepper
Oct 15, 2018Star
Access Control randomly blocking approved devices on V2.2.1.210
RBR50
After upgrading to the V2.2.1.210 router firmware, i'm finding that devices that have approved MacID addresses and have been previosly on the network for months are suddenly being blocked in...
Warrensroad
Jan 15, 2019Tutor
Here is how I fixed mine. Configuration....one orbi router and one satellite. For those with mor than one satellite I'm pretty sure you'll have to place the router as evenly between the two satellites as possible because disabling daisy-chain topology will cause each satellite to connect directly to the orbi router.
Choose Advanced on home screen.
Then Advanced setup.
Then Wireless settings.
Under backhaul topology uncheck enable daisy-chain topology.
| Backhaul Topology | |
| Enable Daisy-Chain Topology |
Reboot the router. Now any device on your network that gets blocked can be unblocked and will STAY UNBLOCKED!!!!!!
I called tech support today and told them about my discovery. I'm assuming that this fix will point them in the right direction and hopefully they will have a patched firmware update soon:)
chrissnv
Jan 15, 2019Guide
Nice find, still everything working as expeced? I am going to wait a little bit longer with upgrading again, maybe Netgear will release a fixed Firmware soon so I can skip the buggy one. (don't want to go back to unstable for now)
- WarrensroadJan 15, 2019Tutor
Man I thought for sure I had it fixed. No such luck. Started blocking again.
What a bummer:(...
However, Iv'e been fiddling with the rip settings and they are currently set to
RIP Direction=Both
RIP version=Disabled
was
RIP Direction=Both
RIP version=RIP_2M
So far so good but I wouln't bet .50 cents on it holding. I'll update in a few days.
Fingers crossed;)
- FURRYe38Jan 16, 2019Guru - Experienced User
Let us know how it goes.
What a bummer:(...
RIP Direction=Both
was
RIP Direction=Both
RIP version=RIP_2M
Fingers crossed;)
- WarrensroadJan 17, 2019Tutor
Disabling RIP version has so far cured the blocking issue.
- mc64Jan 18, 2019Tutor
All of these anecdotal fixes, while interesting, don't resolve the root cause: a software bug. Netgear needs to address that issue. Clearly this is a major problem, but they seem indifferent to the appropriate resolution.
- FURRYe38Jan 18, 2019Guru - Experienced User
You can file a support ticket here and let them know of your concerns about Access Control:
https://www.netgear.com/mynetgear/registration/login.aspx
