qtschlepper
Oct 15, 2018Star
Access Control randomly blocking approved devices on V2.2.1.210
RBR50
After upgrading to the V2.2.1.210 router firmware, i'm finding that devices that have approved MacID addresses and have been previosly on the network for months are suddenly being blocked in...
chrissnv
Jan 15, 2019Guide
Warrensroad wrote:
Reboot the router. Now any device on your network that gets blocked can be unblocked and will STAY UNBLOCKED!!!!!!
Nice find, still everything working as expeced? I am going to wait a little bit longer with upgrading again, maybe Netgear will release a fixed Firmware soon so I can skip the buggy one. (don't want to go back to unstable for now)
Warrensroad
Jan 15, 2019Tutor
Man I thought for sure I had it fixed. No such luck. Started blocking again.
What a bummer:(...
However, Iv'e been fiddling with the rip settings and they are currently set to
RIP Direction=Both
RIP version=Disabled
was
RIP Direction=Both
RIP version=RIP_2M
So far so good but I wouln't bet .50 cents on it holding. I'll update in a few days.
Fingers crossed;)
- FURRYe38Jan 16, 2019Guru - Experienced User
Let us know how it goes.
What a bummer:(...
RIP Direction=Both
was
RIP Direction=Both
RIP version=RIP_2M
Fingers crossed;)
- WarrensroadJan 17, 2019Tutor
Disabling RIP version has so far cured the blocking issue.
- FURRYe38Jan 18, 2019Guru - Experienced User
Thanks for letting us know. You might contact NG support and let them know about what you have found.
