qtschlepper
Oct 15, 2018Star
Access Control randomly blocking approved devices on V2.2.1.210
RBR50
After upgrading to the V2.2.1.210 router firmware, i'm finding that devices that have approved MacID addresses and have been previosly on the network for months are suddenly being blocked in...
F_V
Jan 17, 2019Luminary
Tried the enable daisy chaining option to get rid of the access control blocking trusted devices fix. For me, no go, it first blocked my girlfriends phone when she got home, then some time later blocked mine as well. Did a reboot a few times after the 'fix', oh well, back to the drawing board.
Jan 17, 2019Guru - Experienced User
You might disable all access controls until NG comes out with the next FW update. Sounds like this has been a problem in this version of FW.
