buehlermark
Apr 22, 2019Guide
Access Denied on Some Websites
Firmware Version
V2.3.1.48
GUI Language Version
V1.0.0.354
When I try to go to certain websites like: Rei.com or costco.com, it gives me the following error:
Apr 23, 2019Guru - Experienced User
Might try changing DNS on the orbi to 1.1.1.1 and 9.9.9.9 and see if this might help.
buehlermark
Apr 23, 2019Guide
changed it as requested. Still having error.
Also tried 75.75.75.75
and 8.8.8.8
same results.
You don't have permission to access "http://www.rei.com/" on this server.
Reference #18.a5622317.1555992955.a41aa96
- FURRYe38Apr 23, 2019Guru - Experienced User
And you don't have any parental controls enabled do you?
This is the only site thats given this error thru the Orbi?
What happens if you open a command line window in Windows and run a TRACERT www.rei.com ?
- buehlermarkApr 24, 2019Guide
I do not have any parental controls enabled.
I also was having issues with other websites like costco.com
C:\Users\Mark>tracert www.rei.com
Tracing route to e739.a.akamaiedge.net [23.35.102.196]
over a maximum of 30 hops:1 7 ms 3 ms 4 ms 192.168.1.1
2 19 ms 12 ms 18 ms 96.120.100.185
3 20 ms 19 ms 19 ms po-123-rur101.tacoma.wa.seattle.comcast.net [68.87.206.205]
4 17 ms 14 ms 20 ms po-2-rur102.tacoma.wa.seattle.comcast.net [69.139.164.102]
5 15 ms 15 ms 19 ms be-101-ar01.seattle.wa.seattle.comcast.net [68.86.96.89]
6 15 ms 16 ms 20 ms be-33650-cr01.seattle.wa.ibone.comcast.net [68.86.93.165]
7 17 ms 30 ms 14 ms be-10846-pe01.seattle.wa.ibone.comcast.net [68.86.86.90]
8 40 ms 32 ms 31 ms 66.208.216.182
9 16 ms 17 ms 17 ms a23-35-102-196.deploy.static.akamaitechnologies.com [23.35.102.196]Trace complete.
C:\Users\Mark>
