jeffb99
Oct 23, 2018Aspirant
Access revoked
I have an RBR50 with Device Access control Enabled. What causes a device that has been enabled to become disabled. This always seems to happen at Random times for unknown reasons. Today it happene...
jeffb99
Oct 24, 2018Aspirant
Not sure this is the same issue but thanks. I am on the 2...210 FW release. I tried updating that when this problem started. I use access control for the devices allowed on the network. Even though they have been enabled, they seem to have the access revoked at random times for random reasons. For example, last night one laptop on my network was locked out and as I was re-enabling the device from the router admin, the router revoked access to my admin machine. I had just hit enable the device so I was past the pwd etc. on the router set up software when it revoked. I hope this added detail helps.
Oct 24, 2018Guru - Experienced User
Seems that others have reported this as well. Something NG support should be made aware of if not already.
- jeffb99Oct 24, 2018Aspirant
I agree, just not sure the bast way to do that.
- FURRYe38Oct 25, 2018Guru - Experienced User
You can send the Mods a PM.
I would for now, not use access controls if your not having good experiences with it. Hopefully next FW update it will be fixed.
- jeffb99Nov 01, 2018Aspirant
How does one do that? This is getting frustrating and seems to have been made worse by recent FW210
