John_Ba
Jan 10, 2021Luminary
Access to modem through Orbi
I have asked before but didn’t really get any solution. I have a Vigor 130 modem. When using Asus routers I could access it using its default address off http://192.168.2.1/. Since using a Orbi2 50 I...
CrimpOn
Jan 10, 2021Guru - Experienced User
John_Ba wrote:I have asked before but didn’t really get any solution. I have a Vigor 130 modem. When using Asus routers I could access it using its default address off http://192.168.2.1/. Since using a Orbi2 50 I am unable to log onto it.
Is this the Vigor 130 ?
https://www.192-168-1-1-ip.co/manuals/19653.pdf
This seems to indicate that the default IP address of the LAN side of the Vigor 130 is 192.168.1.1.
Can you please check the Orbi web interface, click on the Advanced Tab, and look at the IP under "Router Information" and under "Internet Port". The router information should be a private IP (https://en.wikipedia.org/wiki/Private_network ).
What is the "Internet Port" IP?
- John_BaJan 11, 2021Luminary
Sensei
The guide to the UK 130, https://www.draytek.co.uk/support/downloads/vigor-130,
Used http://192.168.2.1” Which works OK direct bypassing the Orbi and worked OK with Asus routers befor.
In Router Information 192.168.1.1
Under Internet Port 212.69.54.84
Prodigy
You can’t turn off firewall disabled Armor via app and no connection still, direct address is OK.
Added the modem Mac address to Access Control but couldnt move it up from disconexted devices to allow or block as no responce to address.
- CrimpOnJan 11, 2021Guru - Experienced User
John_Ba wrote:The guide to the UK 130, https://www.draytek.co.uk/support/downloads/vigor-130,
I am "at a loss" to explain this. When the WAN port is a "public" IP address (212.69.54.84), that indicates to me that the Vigor is in "bridge mode". On the support site, I did not fiind a User Maual, but the Quick Start Guide contains this statements:
"The Vigor 130’s primary function is as a transparent bridge modem for
xDSL services – not as a router/firewall in itself. It connects a secondary
router or other device to your DSL line, where that device does not directly
support DSL itself.
As a bridge, the Vigor 130 only provides the physical conversion from
xDSL (ADSL or VDSL) to Ethernet and all firewalling, routing or other
advanced routing functions are managed by your secondary device (a
separate router, firewall etc.). The secondary device may also be a single
PC, a PC-based software router or an Apple Airport™ type device."All I can think of is that the Orbi "knows" that anything beginning 192.168 is a private IP address, and thus cannot be found through the WAN port. Maybe the Asus knew, "it's not on the LAN, so the only place it can be is out the WAN port."
What a puzzle.
Its very frustrating that a device that depends on a further device (modem) to work is setup, it looks, to block access to the device. So the only way either basic or more advanced line device information can be got is by removing the Orbi and directly linking to the 130. When I had a line problem my ISP wanted a lot of line information (and told me how to get it from the 130 as its not shown by default) over more than a week. Anyone looking for how access the full information it is at https://www.draytek.co.uk/support/guides/kb-dsl-status-more. This was no problem with Asus but would be a real pain with the Orbi as at times we were communicating on line and once they took over my PC to show me how to get the detailed 130 data not possible with the Orbi!
