rhg76
Feb 02, 2023Tutor
Accessing https sites - Virgin Media & RBR50
Hi folks We've just moved house and I've brought my Orbi set up with us. Everything was perfect before but now I can't access https sites. We're now with Virgin Media (1gig / Hub 5). I h...
Feb 02, 2023Guru - Experienced User
Armor, Smart Parental Controls or Circle.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
- rhg76Feb 02, 2023Tutor
Thanks for the super prompt reply.
Firmware - V2.7.4.24
Armor / Parental Controls / Circle all disabled.
Virgin Media Hub is in 'Modem' mode, as opposed to 'Router' mode. Is there more I need to do here?
Accessing most websites is absolutely fine. Just a few where I get an 'SSL error'
Any advice welcome? (I'm not super techy).
Thanks
- FURRYe38Feb 02, 2023Guru - Experienced User
Does this happen on different PCs and with different browsers?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Last resort maybe a factory reset and setup from scratch...
