Coco88
Apr 30, 2020Aspirant
Active Directory is very slow using Mesh Wifi Orbi RBK50
I was wondering if I was the only one with that issue. My work requires that I sometimes unlock accounts using Active Directory (connected over a Cisco VPN) and it used to work great from home, b...
Apr 30, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
- Coco88Apr 30, 2020Aspirant
Modem model is a Motorola SurfBoard SB6120.
My Orbi is running in router mode and I have 1 sattelite.
I have done a reset and configured everything back from scratch when I updated to version V2.5.1.8
- FURRYe38May 01, 2020Guru - Experienced User
Something to try with your PC that you are usig, connect it directly to the ISP modem with out the RBR in between. So you still see this behavior then as well or not?
- Coco88May 01, 2020Aspirant
I tried straight from the modem and I don't have that issue.
I don't have that issue neither when I try from another router as well. It only happens with that specific router so far and it used to work just fine with another firmware with the same RBR50 before.
I'm wondering if it's not an option that I changed when I did the reset and configured it back.
I took screenshots to make sure I had the same configs, so I don't think I changed something.
