WeBoat's avatar
WeBoat
Follower
Jan 16, 2018
Actively looking for a replacement
I have had this setup for about 6 months now.  I have followed everything here and updated to the latest beta.   We have had it.  Just passing this on for others.    We are actively looking for a replacement and I can't in good conscious replace this with the Pro version.
At least 3 or 4 times a day we have to take a phone or pad off wifi and go to cellular to do any web work.   Alexa comes on all the time and i'm told it's because of spotty wifi.
I keep hoping the next version will fix it, but have had enough.   Now what to do with 3 units i don't feel good about selling to someone else.
  • Looking for the same advice from this forum. I've spent too much time trying to get sdtability out of my Orbi.
    Velop?
    Lyra?
    Eero?
    I have a 2 story home. 2800 sq. ft. Orbi did a great job before eliminating dead zones. about 20 wifi devices incl. Ring, Bose Soundtouch, 2 Smart TVs, android devices plus google home devices (yes I know that may interfere)
    We watch some netflix. My son games but thatss a direct ethernet connection from our PC.
    • ALNJ2017's avatar
      ALNJ2017
      Star
      I had Velop- worked ok, returned it after reading reviw of Orbi.
      Velop is like Orbi if you can get to telnet interface -access to more features like a 5GHZ SSID.
      • Blcklab's avatar
        Blcklab
        Apprentice
        Can you tell me what you mean by functioned okay?
  • I have a 2800 sq ft 2 story home. Typical suburban stucco construction. Orbi 2 unit covered everything, when working.
    Will 2 unit velop give similar coverage?
  • I started getting tons of drops after a long period of stability.  Read in one of the strings that turning off the new daisy chain feature helped... so I tried it and have experienced significant improvements.  Not sure why they post a firmware with new feature turned on
