TrollHenrik
Nov 24, 2023Follower
Ad new orbi RBR50 and RBS to my network
I have a RBK20 network with two satellites working with bitdefender. I have now bought a RBR50 and a RBS50 (both used) and want to exchange my existing router with the RBR50 and connect the RBS50 sat...
CrimpOn
Nov 24, 2023Guru - Experienced User
https://kb.netgear.com/000063635/How-do-I-get-help-with-my-NETGEAR-subscription-service "Easy" depends on how much effort has gone into configuring the existing Orbi router.
- If the only configuration is the WiFi name (SSID) and password, then simply configure the new RBR50 with the same credentials (exactly). Then, use the Orbi web interface menu Add Orbi Satellite to connect the RBS50 and RBS20 units to it. Done!
- If extensive configuration has been done (would take me two hours to recreate my setup, including time to correct typos), then I would make screen shots of every configuration page. Set up the new RBR50 off-line and not swap it in until everything is configured. Do not set the WiFi SSID until the very last step. This will keep everything in the house from getting confused between the two systems.
Swap the routers and add the satellites to the new router.
What I have no idea how to do is move the Armor subscription from the old to new router. Suggest starting off by contacting Netgear Subscription services:
