MNicastro
Jul 12, 2020Aspirant
Add a second Wi-Fi Network
I have Frontier as my ISP and use a Frontier FiOS G1100 Quantum Router and want to add a Mesh Wi-Fi system. Can I have two separate Wi-Fi networks issuing separate DHCP address ranges (i.e. 192.168.1...
MNicastro
Jul 13, 2020Aspirant
Thanks for the fast response! The reason why I want two separate networks is because I have static IP address on the 192.168.1.x network like server, workstations, printes and four IP cams. They actually all use static IP addresses, so I can disable DHCP on that network, but still need Wi-Fi to connect to the two weather cams. I use port forwarding for the 4 cameras I have and like to keep them on the same network so I can reach them remotely via the Internet. The only reason I want a mesh is bacause the Frontier FiOS Wi-Fi router is HORRIBLE and disconnects my wireless devices randomly all the time, like my Amazon Echo, Ring, Blink, Phillips Hue and other wireless smarthome devices.I figure I can put them on another dependable Wi-Fi network and isolate them from the other network. Makes sense?
CrimpOn
Jul 13, 2020Guru - Experienced User
You may be "overthinking" the situation. The FiOS router can be set to issue DHCP to a range separate from the static IP's that have been assigned to the existing permanent devices. If the mesh network is in AP mode, all devices will ask for DHCP and get passed to the FiOS, which will happily issue them in a range separate from those static IP devices.
If you supply the exact model number of the FiOS router, we can find the command to set the DHCP range it uses. (My guess is that the range is already "OK", because it is currently issuing IP's to smartphones and the like and they are not interfering with those static IP's.) For example, if FiOS has a DHCP range of 192.168.1.2 through 192.168.1.250, and your static IP's are at the top of that range, then the FiOS will never "get that high" and thus never interfere.
I would also disable the FiOS WiFi and let the mesh system probide WiFi to everything.
Having two separate IP subnets can lead to awkward problems, including the dreaded "Double NAT":
- MNicastroJul 13, 2020Aspirant
Thanks again for your quick reply and advice! My Frontier FiOS DHCP is set to default 192.168.1.2 - 192.168.1.254. But I have static addresses within that range as well, like my server 192.168.1.200 and STB 192.168.1.100, and other clients in the lower range. I've been through a couple routers already and they seem to work fine for about 6 months or so, and then they have random issues with IP addresses. I guess I can try to change some of the static IP addresses and move them in the lower and upper portion of DHCP range and set the DHCP to something like 192.168.1.101 - 199. That should be more than enough for other devices.
- FURRYe38Jul 13, 2020Guru - Experienced User
Yes, if you going to use STATIC IPs ON devices, then these need to be outside of the routers default IP address pool. The pool needs to be shortened. I use .100 to .200. This gives me room for static IP addressed devices on either side of this pool. Then Reserved IPs are of course with in the pool that are set ON the router.
