NDH
Jun 11, 2019Aspirant
Add AirPort Extreme to Orbi Mesh Network
Hey all :D I've seen quite a few questions like this, but no really specific answers that I can make out. I now have the Orbi set up at home (1 Router in AP mode, and 2 Satellites around the ...
NDH
That is incredibly helpful - Thank you.
Second question if I may......
I bought the RBK23 set up last week, so still well within the return window.
Amazon have the RBK50 (router and satellite) on sale for £219.00 and the RBS50 on sale for £139.00.
I take it I can't use a Satellite as a router? Although my Orbi router is in AP mode, so could a Satellite replace it here?
The RBK23 cost me £219 (same price as the RBK50 currently is), although the 3 access points work better for me due to the extra ethernet ports.
I could potentially get away with just 2 of the current Orbi's in the house, and move the 3rd to the garage next month - But I fear this will force a few devices to move to the 2.4GHz network at home.
What do you think would be the best route here?
Thanks again :D
Jun 11, 2019Guru - Experienced User
NDH wrote:That is incredibly helpful - Thank you.
I take it I can't use a Satellite as a router? Although my Orbi router is in AP mode, so could a Satellite replace it here? No, you have to have one orbi router in the setup.
What do you think would be the best route here? Best route? Try it. Unplug one of the RBS20's from the house and see how it works for a couple days with 2 of them. If it works great, then you don't have to worry about returning the kit and upgrading. Plus if you're running them with a hardwired backhaul, the upgrade to the rbs50's isn't as much of an upgrade in this mainly affects the backhaul.
If it doesn't quite cut it after a couple days of running, then upgrade.
- NDHJun 11, 2019Aspirant
I feared you'd say that - The Amazon offer is only for today (it's "deal of the day"), so I don't have too long to decide.
I've unplugged the one that I would remove (to put in the garage), and the signal is still fine, but it reverts back to the 2.4GHz network on my iPhone (annoying).
I used to have just 1 AirPort Extreme for the entire house which covered it in 5GHz speeds for the most part (2 separate SSID's for each frequency).
We are also upgrading from ADSL which runs at 17mbps to Fibre which runs at 36mbps (happening on Thursday).
This may make enough of a difference that I don't need to worry about the 2.4GHz network speeds in the living room, and mean I don't have to buy a 4th AP.
Does that sound like a reasonable assesment (given you clearly know about this, and I really don't!) lol.
Thanks again.
- plemansJun 11, 2019Guru - Experienced User
How large is your house? Material its made from? Concrete, brick, hvac, and foil lined insulation do a great job of blocking signals. Moving them around to optimize can help with speeds.
the iphone might switch back to 5ghz. Orbi dynamically adjusts for bandwidth distance needs.
How many wireless devices on your network?
Orbi should be able to max out a 36mbps connection without much problems so it sounds pretty reasonable.
