genedoms
May 01, 2018Aspirant
add an outdoor satellite RBS50Y
I just installed an Orbi mesh router with 2 indoor plug-in satellites and am about to install 4 Arlo Pro 2 cameras. I would like to install one outside down my driveway approximately 300 feet away an...
DarrenM
May 01, 2018Sr. NETGEAR Moderator
Hello genedoms
The outdoor orbi would not connect to your Arlo cameras. The cameras connect to the Arlo base station and there is no way to connect the base station to the outdoor orbi as it does not have a ethernet port.
DarrenM
- genedomsMay 01, 2018Aspirant
Thanks Darren. That's a drag but it makes sense. I will just have to reposition the cameras to get the best coverage I can.
Gene
